bruinbear714 wrote:
Step 1 - Restore car to OEM specs and make sure you get the proper specs for the TPS at no throttle and at WOT, MAF @ idle, proper O2 reading, proper coolant temp reading, and proper timing.
Step 2 - Make sure wiring is correct and nothing's shorted, crossed, or mixed.
Step 3 - Tuneup.
What I've done was restore car to proper specs as much as I can, I at least learned that from Uti lol. I've had to make some adjustments.(which I will explain shortly.)
wiring is correct (as much as it can be...) the car does need spark plugs though. It's basically a new engine, tore it down, built it back up, all new bearings, some better condition pistons, new maf, tps, cas, fuel pump (255), seals.
I really do appreciate the help man.
NOW, the problem is with the fuel system. A friend kinked the return line and it kept an idle. of course this is after I replace the b/y wire to the pump because it had high resistance on it and the pump was only getting 10.3V. Now after some fiddling with the relay, the pump only gets 7.3V. (and the car won't start at all)
I hard-wire the pump to B+ with a switch and fuse to just say screw the relay (which at this point stopped working) and the car starts and runs again (after being jumped, and the bolt on my Nismo fpr is almost all the way in.)
I buy a fuel pressure gauge today, put it in-line, set it properly (43.5psi off, 36psi @ idle) and the car idles, but HORRIBLY. kink the return line again and it runs SLIGHTLY better.so a friend bumps the fuel pressure to between 60-70psi @ idle ( I wanted to leave it where it was) and it idles like it was when the return was kinked. (I need to mention that it does not hold a steady idle, RPM & vacuum fluctuate a bit)
I unplugged the maf at one point and it ran about the same. Everything seems to make it a bit better though.
I finally drive it like a total of 200 feet, it dies a couple times after I let off of the throttle, under a load (boost) it still hesitates, doesn't want to get out of it's own way. (At least it's moving now.) I got some video of the idle when the fuel pressure was ~60psi. this is with my phone since my camera was inside the appt.If you look under the Boost gauge, dunno if I got it in the vid, but the narrowband a/f gauge wasn't reading anything at all. Usually when I drove it would be switching (or off) and when I hit boost it would show pig rich, now it doesn't register anything(it just stays off). I will check my O2 sensor tomorrow to make sure it's just the gauge and not the sensor.
I know I'm forgetting something right now, but I'm dog tired. be back with more info when I'm refreshed. Hopefully when this is resolved, someone else won't have to go through all of this to find their problem. And if someone else has been through this already I'd appreciate some insight.
