Yeah, the car runs fine, idles fine, etc. But as for the cut out, I am assuming this probably has something to do with the MAF fuel cut. I was reading on some chip tuner websites that if the MAF sensor senses too much air coming in it will cut fuel. This makes sense because alot of the VW guys 1.8t motors have this problem when they put in K&N drop ins or intakes. So we think this will get fixed when we get a chip to take away all the limiters and cuts.
HOWEVER, the big problem we have run into and are scratching our heads over is the MPH gauge. It doesn't read MPH, and we have tried so many things. We even tried to hook the speed sensor straight up to the ecu and dash and bypass the rest of the harness to no avail.
After looking at several autotranny wiring charts, I think we may be running into a problem with a plug. The chart shows the auto's having a plug right behind the ecu plug code named "F3". In the auto trannies this plugs into a harness that runs into the Automatic Transmission Control Unit. So since we are using a auto harness in a car that had a manual that plug and control box doesn't exist. Long story short, I think by bypassing that control box it doesn't allow the sensor to complete its circuit. I have no idea how to get around this.
