Help car acting up again...
92SR20S13
Car: sr20det-s13
Well i just replaced my head gasket and everything is now back together..but one problem..when i go to start the car thers a really slow cranking sound..pretty quiet and will only happen for about 1-2 seconds..and if i hold the key all the way over (to starting position) the passenger side of the engine bay starts to smoke bad. Any ideas?..all my grouds seem fine..im totaly stumped
SpeedRacer1
Car: 1990 240SX, G35
Did you reverse your alternator and starter power wires? This would blow the alt fuse and cause the engine to either not turn over or barely turn over.
92SR20S13
Car: sr20det-s13
nope...and i took off the alternator today and bench tested it..still works fine..so what could cause the smoking?
natguerrero
Car: 240sx sr20det
where is the alternator fuse ??i have the problem where my car wont turn over ! but the alternator it self is good !
SpeedRacer1
I didnt say your alternator was bad, I said that you reversed the power wires to the starter and alternator. Therefore when you tried to turn over the engine, the power was sent to the alternator instead of the ECU. This causes you to blow one of the big fuses in the fuse box (75 amp or something). This could account for smoke if its near the fuse box in the engine bay.
The alternator fuse is located in the passenger side engine fuse box. I cant remember exactly what the fuse is called off the top of my head, but just check to see that none of them are blown and you should be good.
92SR20S13
Car: sr20det-s13
No i didnt hook the wires up backwards...i know for sure i didnt. My 75amp fuse is good and so are all the others..im totally stumped..my SS braided clutch line is what apears to be smoking..burned right through and theres clutch fluid pouring out of it..any more suggestions?
driftking91
Car: 1991 240sx
Check the plastic power isoltaor on your alternator if its loose your grounding the thick white power wire to the alternators body when you hook it up. (Its the plastic ring around the bolt sticking out of the back of your alternator where that white wire goes.
92SR20S13
Car: sr20det-s13
Pl
driftking91 wrote:Check the plastic power isoltaor on your alternator if its loose your grounding the thick white power wire to the alternators body when you hook it up. (Its the plastic ring around the bolt sticking out of the back of your alternator where that white wire goes.
Plug is good..Could not having the ground on my hatch hooked up cause this...im going to ground it now and i doubt thats the problem but we will see. I also found out what was smoking and it was my SS clutch line =S...burned right through the inside and now theres clutch fluid all over. I think i burned everything off of it because it dosent smoke anymore..im SO lost on this.
92SR20S13
Car: sr20det-s13
grounded my hatch and nothing...i checked to see if i was getting power on the motor with a mutl meter and i read 0.05v on the motor..and one black wire coming from the lower harness i have no clue where it goes but it also reads 0.58...i dont think it was ever hooked up before
92SR20S13
Car: sr20det-s13
Ok ive discoverd 2 black wires wich arent hooked up....one coming from the starter harness..and the other from the alternator harness...both with loops on the end...any ideas where these would go? test them aswell with my multi meter and nothing...i also tried ground both to the car and nothing aswell
92SR20S13
Car: sr20det-s13
Ok so the car now starts...but for the first while if only on light throttle the car would sputter at 2k rpm..and under full throttle it would go but the power didnt seem to really be there..now when i start the car and lightly bring the revs up in neutral it does the same thing little sputtering and wont go past 2k rpm unless i stepp on the gas all the way...then under load if i try to boost it just sputters and wants to die and if i let off the throttle it still wants to die and dosent idle properly unless i shut the car off and start it again. Also if i try to boost and then let it idle and the idle is really rough i get black/grey smoke out of the exhaust and after a while it started to smoke more grey/white...any ideas on what this could be?...
