C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Jun 04, 2008 8:16 am
The AV controls and the A/C or on the same circuit board. Sounds like you may have a failure in there somewhere. You can try a "reboot" as suggested, but I doubt it will help (no hurt in trying of course). You might run through the troubleshooting diagnosis in the FSM if you are mechanically competent (Bearing in mind that removing the center stack in the 03-04 is quite complicated. It requires you to remove quite a bit of the dash on either side of the stack to get to things (trusty me, I've done it once). Add to that the bexel is painted and very easy to scratch. If this sounds too risky, you might try taking it to the dealer.
