HELP! Bushing kit for G20?
I've been looking and looking for a full kit of polyurethane bushings for a 95 G20...
At this point, I'll take plain rubber, or buy them a piece at a time... Any ideas?
Chris859
Im not sure on the rest, or even this - but can you use the control arm bushings from a b14 200sx/sentra? If you can - I have a new set you can pretty much have for pocket change.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Did you try energy suspension?
Chris859 wrote:Im not sure on the rest, or even this - but can you use the control arm bushings from a b14 200sx/sentra? If you can - I have a new set you can pretty much have for pocket change.
I'd be interested, the LCA bushings on mine are literally GONE.
Yeah, E.S. doesn't even list the G20.
EDIT - Nothing matches. Found a set thru Superpro.
Thanks all!
RED_DET
Vendor
2011 Infiniti G37x
Superpro is probably your best bet. for some reason the market for g20's is limited on quite of few after market items. Its amazing they make energy suspension motor mounts inserts for every other sr20 vehicle except the g20. completely dumb.
raw0330
Car: 95 S14.5, 99 P11, 85 S12, F4i, F2, R1
Get on G20.net. Do a search for traveling prothane motor mounts. The guy's name is Pat that actually mods adn presses the prothane engine and trans mounts from a sentra to use in the g20. I got the front and rear engine mounts from him for the wife's P11 and they work great!!
