Blown240sx »
https://forums.nicoclub.com/blown240sx-u28058.html
Tue Oct 17, 2006 2:25 pm
400 crank or wheel? Crank your right at the limit I would push a SR without a full rebuild.
I recommend though for logevity break the block down. Have everything clens and resurfaced, balance the crank shaft, get the head cleaned and polished. Then put in new cams 264 or larger, new valve springs, retainers, new lifters, and valves. Then put in new pistons, new rods, all new bearings, and new seals.Then probably youll want either a GT2871R since it makes 500 crank with stock mounting location or go to a topmount with external gate. 2871R might be your best bet.Then youll need injectors, fuel pump(if you dont already have one), FPR, and some type of tuning either chipped ECU w/a piggyback to fine tune or Stand alone.Of course you will need a FMIC and Z32 MAF.You will need a hardcore clutch and might even consider going to a Z32 Trans w/ adapter plate.
