You mean decked? No that's wrong. There is no reason to deck a head after removal unless you are using a metal head gasket. And if you deck the head you have to deck the block...UK-P11GT wrote:u should always get the head skimmed and a new gasket every time its removed.
not sure wat decking is, but over here in the uk when we pull off head we cnc skim 3/4 thousands of an inch off the head incase the head has flexed wen loosening the head from the block. the block doesnt have to be machined, its machined cast iron, after its initially machined by nissan. when taking the head off the block doesnt have to be altered apart from new head bolts which should also be used.Im not sayin all this to prove u wrong or anythin, I used to do it at college and made a living building sr's and rb's.redtop91 wrote:
the block is cast iron, it wont warp. cylinder heads are made from aluminium or a light alloy. there prone to bend a block cant really bend much with heat.removing/refitting a head is not easy/cheap or fast! regardless of how good a mechanic you are!I think you'l find if u refit a used gasket u wont get a perfect seal. should maybe get a bit more info.redtop91 wrote:I dunno. I've never had to deck (shave off a thin layer to make sure it is flat) a block after removing the head and I've never had any problems. Also if you shave the head to be flat and not the block (which will have warped along with the head) you won't have a proper head gasket seal. Irregardless if I was in his shoes I'd remove the head. It is easy, cheap, and fast.
