sil80tt »
https://forums.nicoclub.com/sil80tt-u81371.html
Sat Apr 26, 2008 9:33 pm
Hey wassup! Im just rebuilt my SOHC Ka24e! I have Forged ARIAS Pistons and stock forged rods. Really proud of it untill i started it up for the first time. When i turned and cracked it a couple times to start it it would make this weird clunk clunk sound. Then i poured oil into the spark plug holes to make sure the oil rings were sealing. We cranked it again, the car turned on, revved the rpms to about 2500 then let go of the accelorator the cars bogs down and turns off. I restart it again then repeat the revs. Same problem. I then do a compression test and cylinder leakage test on all 4 Cylinders to check my compression and im gettting very low numbers 80's to 85 on the gauges from Cylinders #2 and #4 But im getting 125 even on cylinders #1 and #3. What could be causing this problem and what can i do to fix this? PROFESSIONAL TECHNICAL HELP IS HIGHLY PREFERED! THANXS
Modified by sil80tt at 1:10 AM 4/27/2008
Modified by sil80tt at 11:55 AM 4/27/2008
