help!bought ca18det motor 2 broke parts,what to do
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
the plug goin to ecu is broke in half,will ka24e plug mate up?the idle air control valve is broke[aac]-what is a replacement.the guy who sold it to me told these problems in advance.please help me out ca gurus.sorry,its actually the aac valve is the broke part,do i need this if im not runnin ac.
Modified by splintercell at 11:25 AM 3/8/2006
Bwana
Car: Denali
I have both of those parts. If you're interested send me an email. bawana at frii.com . The plug would have to be spliced in of course, unless you want the harness.
boost_boy
If you are not running a/c, you don not need it the broken valve, but you will need to leave the main body of it screwed in place.
Dee
splintercell
will the ka24e ecu plug be mated in place of the broke ca plug.
boost_boy
That part is not CA specific, so you possibly use it off other engines.
Dee
biosehnsucht
ka-e won't work for sure. don't know about ka-de
s14 sr is the same, don't know of anyhting else off hand.
NismoBgt
Car: 1974 MBG GT with a CA18DET
I belive the only ECU plug that matches up to the CA18DET ECU is from the Q45. But I also have a spare plug. IF you need it let me know.
splintercell
im not running ac so the aac valve wont effect me none,but i get the engine today,so i will let you know if i need the plug.thanks
splintercell
the aac valve was alright ,but im not runnin ac anyways.it was the idle air control valve that was broke.do i absolutely need this.also you would know what i should ask for at the parts store for power steering pulley.my engine must of been on the bottom of the container shipment.my pulley is wobbly,argh.
