help! boost or no boost?
Fancy_Footwork
I recently compression checked my dohc and found that my 2nd cylinder is pushin only 120psi compared to the other 3 cylinders at 180-190.
Wet test on #2 put it up to 180psi.
So, do I build it and do it right? Or do I boost that bad boy until she blows?
Thoughts?
trackslut240
Car: 1993 Nissan 240SX
fix one cylinder, boost it, blow it up, then build it fully and boost away...
u got the time and money? then do a full built and boost, if u r poor like me, fix one cylinder and boost till kaboom...
honestly, once the boost bug bites, u will want to blow it up soon and build a stronger motor...
RUHNAy
Car: nissan 240sx fastback
IS THIS YOUR DAILY DRIVER ???DO U HAVE A SPARE CAR ?DO YOU WORK ?NOT TO BE NOSY BOUT WHEN U THINK ABOUT IT IT ALL DEPENDS IF I HAVE THE MONEY TO BOOST AND REBUILD I WOULD REBUILD FIRST THAT WAY YOU HAVE A MORE RELIABLE CAR IMO ....THEN AGAIN IF ITS UR DAILY DRIVER AND IS YOUR ONLY WAY OF TRANSPORT THINK ABOUT HOW UR GONNA GET TO WORK I F****D UP BIG TIME WHEN I DID MY SR SWAP ! WORST THING I EVER DID TOOK THE SHOP 2 WEEKS OR 3 TO GET THE CAR UP AND THE WHOLE TIME I HADTO TAKE THE BUS TO WORK WITCH WAS A 30 MIN DRIVE AND BECAME A 4 HOUR BUS RIDE LIKE I SAID IT ALL DEPENDS ON THOSE THINGS I KNOW ITS EXITING AND TEMPTING JUST TO BOOST IT BELIVE ME BUT TAKE ADVICE FROM ME....DO THINGS RIGHT THE FIRST TIME AND YOU WONT BE DISSAPOINTED I WOULD JUST DO THE REBUILD REMEBER TYOU CAN ONLY HAVE 2 THINGS OUT OF THE 3 (CHEAP,RELIABLE,FAST)NOT ALL 3 HADTO LEARN THAT THE HARD WAY
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
^must you yell?
Fancy_Footwork
RUHNAy wrote:IS THIS YOUR DAILY DRIVER ???DO U HAVE A SPARE CAR ?DO YOU WORK ?
Not my daily. The 240 is my joyridin car, I've got a reliable daily.
I work at a dealership, which is good enough to allow me full use of its facilities when I'm not working. So I can buy a stand, keep the engine at work and build it at my leisure.
I'm well aware of the possible complications of going for broke and just blowing it up. Either way I have the facilities and knowledge to fix it. I just wanted to solicit opinions on the matter.
On the rebuilding subject, has anyone used AMS's "Advanced Rebuild kit"?It has what looks like all the right stuff to build a car well within my power goals ( 500-600hp) as well as all the timing chain parts.
I mean if AMS built one of the most powerful EVOs in the country and one of the most powerful KA-T's, I'm sure they'd have put together a pretty stout kit based on their knowledge.
