HELP Blue smoking need HELP
300ZXttZMAN
Ok so i have a 1990 300zx tt 5spd (factory turbo not a swap) 107k miles on everything i just bought it and replaced plugs with oe plugs... I have heard of when the turbos start to go out that the oil inside the turbos will burn up and thats where the blue smoke. the thing of it is is that the turbos spool up great :chuckle:
IF ANYONE HAS HEARD OF THIS PLEASE SUGGEST SOMETHING HELP HELP HELP
THANKS IN ADVANCE
dantesdoom
Car: 1991 Nissan 300zx N/A
1997 Nissan Pickup
blue smoke all the time or just on crank up...if its all the time, your rings could be going out
300ZXttZMAN
its until it warms up
es.biggs
Car: 1990 300ZX 5sp NA
Does it seem to be worse in the morning when you start it up? That's a sign of leaky valve stem seals...oil leaks down very slowly and sits in the valves and gathers over night or when parked for a long time - and it will smoke until that oil is burned up.
300ZXttZMAN
let me say this it does have an exhaust leak right before the cats would that make it smoke ???
awesomekasim
Car: 1991 300zx TT 5spd
Do a compression test and leak down test. Compression test will tell you if piston rings are bad and leak down test will tell you if oil is leaking past the valves. If both are good, then your turbos might need attention.
