spider_slayer »
https://forums.nicoclub.com/spider-slayer-u20388.html
Tue Jun 07, 2005 11:35 am
sdtounge - there is an air bubble in your system. bleed your coolant system. use the bleeder screw on top of your manifold. my car was doing that for a while, smoking thick white smoke every now and then at idle.
Dawgmode - i'm honestly kinda stumped. you are describing the symtoms of a blown headgasket. are there any visable leaks anywhere? like after sitting for a night or 2 has any coolant leaked anywhere? i'm also going under the assumption that you have checked all of your clamps and made sure they are all tight. one thing that wouldn't hurt would to be pulling off the valve cover and seeing if the oil is ok...if any coolant is in the oil your oil will be a milky color. the only other thing i can think of would to be use the FSM method to bleed your coolant system and make sure there is no air in it. i don't think it will help any however but it can't hurt. i'm out of ideas, good luck
