help bleeding the cooling system
i4jdm
Car: 1995 240sx (s14) kouki conversion
update-------
all seems fine but random heat spikes when driving fast. like speeding up for getting on the highway.
Modified by i4jdm at 4:00 PM 11/22/2009
jeff420
Car: too many to fathom
i dont see how ppl have a problem doing this, i NEVER have problems. one member on here posted a nice way of doing it, using their words "POUR SLOWLY".
the way i do mine id i have one of those small gatorade bottles i cut the bottom of it off. the cap end (with cap removed of course) fits right into my radiator perfectly. i pour coolant in until its full and pour some more in so the gatorade bottle has some in it, then i start the car and if i need to add more, i add more. while the engine is running and the heater is on full blast i squeeze both upper and lower radiator hoses ensureing any air bubbles still in there get dislodged.
btw search. theres many threads on this topic.
i4jdm
i am searching bro thanks
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
take a jack lift the front slightly.take radiator cap out.take bleed screw offtake a 2 liter pepsi bottle cut it in halftake some black electrical tape and wrap the bottle neck a littleflip it around and place the bottle neck were the radiator cap was at.have somebody start the carturn on the heaternow start filling it with coolantclose bleed screw after you get a nice even stream of coolantadd antifreeze until you over fill the rad by a quartlet the engine run after 3 minutes the thermostat will open and suck in the exess antifreezefill it again but with about a half of quart.let it run until no more bubbles come out.replace cap and enjoy
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
w
jeff420 wrote:i dont see how ppl have a problem doing this, i NEVER have problems. one member on here posted a nice way of doing it, using their words "POUR SLOWLY".
what if you dont have heat..
i4jdm
Lonismos14 wrote:wwhat if you dont have heat..
OutToWinPAHC wrote:take a jack lift the front slightly.take radiator cap out.take bleed screw offtake a 2 liter pepsi bottle cut it in halftake some black electrical tape and wrap the bottle neck a littleflip it around and place the bottle neck were the radiator cap was at.have somebody start the carturn on the heaternow start filling it with coolantclose bleed screw after you get a nice even stream of coolantadd antifreeze until you over fill the rad by a quartlet the engine run after 3 minutes the thermostat will open and suck in the exess antifreezefill it again but with about a half of quart.let it run until no more bubbles come out.replace cap and enjoy
ok so i did what i think to believe the proper method of bleeding and the only time the temp spikes is now when i do spirted driving. like shifting at 4-5k.checked for leaks none. its def not a headgasket as for no smoking if it was the water pump it would be leaking so.....bad cap maybe
Harman850T5
Car: 2003 350z
There is a spill free funnel kit for about $30 you can get from Matco, Mac, or Snap On, that really helps with bleeding the cooling system. It uses the same principle as the gatorade bottle, but it comes with adapters to mount the jug to the radiator or even the overflow tank in some instances.
It also helps to squeeze the hoses being careful of not catching your arm on the fan, and reving the car up to speed up coolant flow.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Maybe. If your not leaking or burning it, check the oil incase it going there.
Just get a coolanbt funnel and new cap, fill the funnel 3/4 and keep squeezing the lower and upper hoses and burp it all out. Then bleed it.
If you keep getting air into the system, then there is an issue.
i4jdm
OutToWinPAHC wrote:Maybe. If your not leaking or burning it, check the oil incase it going there.
Harman850T5 wrote:There is a spill free funnel kit for about $30 you can get from Matco, Mac, or Snap On, that really helps with bleeding the cooling system. It uses the same principle as the gatorade bottle, but it comes with adapters to mount the jug to the radiator or even the overflow tank in some instances.
i think bleeding is done. the only problem i see is random temperature spikes when i driving fast. you guys think i might have some air trapted somewhere?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Most people don't bleed it long enough. Heat on, idle a good while. Sometimes it can take 15 20 minutes for a t stat to open. A little throttle helps too.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Did you install the Tstat correctly? Little hole to the top?
i4jdm
OutToWinPAHC wrote:Did you install the Tstat correctly? Little hole to the top?
yes its was on top. Ive left my car idling for the last 15 mins but i put back the cap and screw about 8 mins ago should i take em off and go a full 30 mins. car hasnt overheaded or anything but that air in the cabin is notiable hotter than before i changed the thermostat. (maybe i should take her out for another quick drive)
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
No shut it off, let it cool down, then check to level and burp it again. It might need a pinch.
i4jdm
OutToWinPAHC wrote:No s*** it off, let it cool down, then check to level and burp it again. It might need a pinch.
hey thanks bunches for the help ill let it cool down then give it a go again...ill report back later with an update
jeff420
fyi just because you dont have smoke or coolant in the oil doesnt mean you dont have a blown headgasket. sometimes exhaust gasses will push the coolant out of your overflow. happened to me before.
if you dont have your heater core hooked up then you dont have to have the heater on.
30 dollars for a bleeding kit? meh. id rather go spend a couple bucks, drink the gatorade, and recycle lol. the small gatorade bottles are the perfect size. ive used 20oz and 2 liters with the electrical tape before it works ok.
fastass
Car: 95 240sx
use a 2 liter and a gear oil cap with the spout cut off completely it seals and does a great job..
i4jdm
everything turned out great thanks to those who helped!
