Help !!! Best Way to get engine back on its mounts?
300max
Car: 1995 240sx ka-t 1997 Maxima SE
I originally posted this on the KA board but there doesn't seem to be as much activity over there. If a moderator wants to delete that post, feel free.
I jacked up my engine to gain access to the oil pan for my turbo return fitting. However the engine is now off of the mounts and is not lining up as needed. What's the best way to get it back on.
I don't have an engine puller all, All I have is various jacks and jacks stands.
Any help would be appreciated, Thanks
Tictakman
how far is it off? mine did that once and all i did was use a little leverage to push it back in until it fell into the slots. just jack the motor down till it just rests on the plate, then use a broom stick or somethin to move it, should fall back in.
Zak
Tech12
Car: 91 240sx Super Hicas
since the motor mounts are pretty flexable, all I did was loop a piece of rope around the bolt, and pull in the direction that I needed... Then lowered the motor halfway down the bolt, removed rope, and finished the job.-Lech
[edit] Sonofabiatch! Just noticed you (Tictakman) are also in the nasti nati. Shoot me a msg sometime on AIM: BiggLekk... oh, and got a timing light?
andrave
Car: 1989 Nissan 240SX Coupe
I used my brother and a big pry bar to help get mine on.
574-240sx
Car: Nissans, Toyotas, Subaru
Jack and a pry bar. Once get get one side in then you attemp the otherside it keeps popping out. Just leave some pressure on them but jack the engine up a little so not all the pressure is on them. They just use the pry bar and pry in the direstion you need to go. Watch for fingers when they do go in.
