absolute »
https://forums.nicoclub.com/absolute-u10611.html
Thu Oct 28, 2004 5:50 am
well hopefully you loosened the motor mounts from the top. at least i think it'll be easier to get it to line up. the olts on the bottom if loosened will allow the mounts to slide a little, notice i said little bit up and down, and very little from left to right.that way lowering the motor, which should be able to roll slightly if you jack has wheels , and the small flexibility of the mounts will make it easier to line at least one up. you'll have to rock "or using a pry bar as everyone stated" shift the motor. once one is lined it shouldnt be too hard to get the other one you just have to readjust and tighten the mounts again, but should and will are too different dammits, and yes it will be easier with a friend.
