HELP!! Belt
Tx-Sx-FS
Car: S13 KA-T
In the process of swapping motors and cleaning it up, I apparently lost my powersteering pump i have the brackets but not the pump..here is the help part: Is there anyway I can run the motor without that pump? I dont plan on using powersteering, but my teacher said I needed it for the water pump pulley. Is there any belt that will fit tightly enough to run the water pump pulley from the crank pulley?? if not let me know. TIA.
Tx-Sx-FS
Car: S13 KA-T
bump...wheres the help?
wild_maxx
Car: 90 TT pearl yellow z32
error- can't reply... sig to big... -error
lrb_2000
Car: '91 Nissan KA-T hatch
i'm getting the same error.. weird.
Mishka
Hey! Your teacher is right, the same belt that drives power stearing pump, drives water pump, and cooling fan (if you haven't switched to electric fan, yet) I think that you would have a problem not having the power steering pump installed because it also works as a tensioner for this specific belt.
Somebody else would probably have an idea how to install belt without tensioner.
Mishka.
wild_maxx
what motor is this on? DE or E? if its the E.... i think the WP runs on the same belt as the alternator and off the crank pulley.
TheOne
Car: 93 240sx FB
DE, and damn good point there mishka, didn't think of that when i was lookin around that, so am guessin replacing the ps for some sort of tensioner?(sort of using the same pulley but removing the ps, that'd require some welding and thinkin)
Chezedik
Car: 1991 Nissan 240sx
Just my first read, and I guess that becomes a bump. The DE runs the WP on the same belt as PS, so it would require some sort of tensioner or idler to function (don't ask how I know), but I have only been under the hood of the E once, and am not sure, if I remember the PS runs on the opposite side of the motor, so the WP should not run off of it. Basically, if the WP has no belt, then you are ****ed.
Tx-Sx-FS
Car: S13 KA-T
ok..for the 2 that made a stupid comment about my sig... F OFF...and the others that attempted to help..thanks..but im just trying to see if anyone knows about me just running a belt from the crank to the water pump, if it was small and i were to stretch it some to fit over both pullies tightly.
Mishka
Belts do not stretch.I think I have an idea.There is a tensioner pulley for A/C right below, I think you can use this one.Remove A/C pump belt also, then replace the bolt on the A/C belt tensioner pulley with a longer one, install a spacer between the pulley mounting bracket and a block ( so it would come in line with Water Pump/Power Steering Pump belt and use it as a tensioner.
But it deffinitely is a bad idea. This is not the belt you want to play with. Just find a PS pump. Mishka.
Chezedik
It is important to understand that if the angle isn't 100%, the belt will burn up and jump off track.
virus77
Car: 95 S14, 71 240z, 97 e320
Here, use this image, you have too much whitespace on the one you are using.
Chezedik
A beautiful pic, but the black wheels with a polished lip are rice, AND I LOVE THEM! So anyone can talk crap, but your S14 looks very decent.
wild_maxx
Tx-Sx-FS wrote:ok..for the 2 that made a stupid comment about my sig... F OFF....
**** u... learn how to post up the proper information.... If you just look at your belts you would know that you need that belt...
Tx-Sx-FS
Car: S13 KA-T
wild_maxx: just stop posting, i know i need the belt, im trying to find an alternate route without hurting my motor D@MBA$$
Virus: thanks for the new pic.
Mishka: I have DE, so the ps is on driver side..thanks tho.
Im just going to get another pump and slap it on without fluid and see how long it works.
virus77
Chezedik wrote:A beautiful pic, but the black wheels with a polished lip are rice, AND I LOVE THEM! So anyone can talk crap, but your S14 looks very decent.
Are you talking about my car. Because thats my sig, I reposted his pic with less whitespace so he can use it in his sig, your wording confuses me.
Ive never had anyone talk crap about my S14, not that im jesus or anything but I take pride in my good taste and quality parts used to make my car the way it is. Also my Volk Racing GUNMETAL 18s" from 1997 (before the term rice was invented) are nowhere near rice. Black on chrome 15" with 45 offset from pepboys/kragen are rice.
eddiec
Car: 91 S13
as everyone has mentioned, you'll need to adjust the tension somehow. if i was trying to do what you are then i'd get a tensioner pulley and bracketry from a pullapart and make it work. bearing in mind that the belt does not like being run at an angle.
Mishka
Quote »Mishka: I have DE, so the ps is on driver side..thanks tho.[/quote]So is the A/C compressor and pulley, if you car is equiped with A/C.
Chezedik
No, not talking crap, I like them. Everyone gives me **** for liking the polished lip. But I think they are slick
PapaSmurf2k3
Site Admin
just get a power steering pump. also, why run it w/out fluid? why not just hook it all up?anyways, if you cant find a PS pump, talk to fiznat, i think he has like 3 laying around collecting dust... then ask him when hes coming up here and partying
