HELP BB problem!
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Ok so my brakes were rock solid after I did my SR swap.. last time this happend I got a new brake booster and it fixed the problem. Well I took out the brake booster and I found that when the car is running the BB line is not pulling a vac.. No air movement whatsoever... WTF? I have the one way valve thingy thats in the line, facing the correct direction (arrow to driver side) What's up?
ser2102
Car: 91 dead. 90 getting did
i think the arrow points to the engine, not the driver side. take it out, anf flip it around. or blow in it in each dirrection to make sure its the correct way. it wont go through if you have it facing the wrong waay.
