owinbush »
https://forums.nicoclub.com/owinbush-u27549.html
Thu Mar 26, 2009 8:56 am
You will need 4 universal air aerosport bags. the required valves probably 8 for front back side side adjustment, along with all the fittings and air line. probably 2 compressors although you can get away with one, a switch box, and some experience with wiring and minor fabrication. Or a good installer.
It appears by your questions that you are a little new to this level of modification, but you could probably do it yourself since using the aerosport bags effectively limits the amount of fabrication you'll have to do. But you should have some good and I'll venture to say extensive wrench turning experience before you try this one.
you're right the bags do slide over the stock shocks however, you may have to modify or weld brackets to the shock body in order to have the bags seat properly to prevent leaks or bag failure.
I'm about to install air on my y33. I've converted the front suspension to s14 components and I'm running NISMO coilovers with bags for a dampening adjustable bagover suspension.
