adidas2go »
https://forums.nicoclub.com/adidas2go-u78832.html
Sun Sep 13, 2009 7:49 pm
This is the block diagram lighting schematic for that particular circuit for the Altima Coupe from the field service manual.
The wiring goes from the stalk switch, to the body control module, to the tail lamp relay, then to each individual light. Pretty simple circuit. Now, if all 4 of those items aren't working, then you have a problem before those 4 points. Either the relay, or BCM. The combination switch wouldn't be affected by something like this.
Now, from what I've read, you said the tail lights still work like normal, which would mean the switch, bcm, and relay are all working correctly. I believe your breakdown is a wiring malfunction. What did you actually do when you tried to wire in these lights? You just used a wire tap right?
Here's something I want you to do. Check all 4 of those lighting points off the relay, make sure they are work correctly (besides the front parking lights of course).
Also, hit the emergency signal button above the radio. Let me know what lights work with that actuated. Hopefully we can figure this out without involving Nissan just yet.
