What kind of Motegi's? Good luck with the swap.NismoChick97 wrote:I know!!! lol... Im replacing them.. I've had those rims forever.. before I did all of my work to the car. Im looking for some motegi's right now.
Thanks for the info.!!
17" or 18" DP10... I want a carbon fiber center cap. :-) I really dont like the one's I have on there anymore... but I threw out my stocks.. so, they are there until I find my new ones... I found the exact one's at a Tire Kingdom here, so I should have them soon!!!NSR_S13 wrote: What kind of Motegi's? Good luck with the swap.
The Avenir ECU.. it was out of an Auto and mine is Manual.. they said I could use it.. just have it tuned.... I am just going to replace the Avenir wiring harness with the SR20DE one... Hopefully, I can get this going!!!nametakennow wrote:The GA16 harness will not work with an SR. There is a guide to going from GA->SR as a sticky near the top of the Sentra Gen page. Also, do you mean the stock GA ECU or the stock Avenir ECU? The car definitely won't run with a GA ECU.
Look for FWD SR20DET parts and avoid GTi-R - specific parts (so look for Bluebird/Avenir by whatever you're looking at) and you'll be good.
nametakennow wrote:Hmm... wait, so you're running an Avenir harness? I don't see how it would have plugged up with your USDM car...
I don't know where you'll get tuning for an Avenir ECU. You may have to look for a B14 USDM SR ECU and send it to JWT.
