Kovar68 »
https://forums.nicoclub.com/kovar68-u138912.html
Wed Jul 22, 2009 9:19 am
Here's the deal I bought a used 1993 sentra E the owner said that i needed to go thru the range of the transmissino before i turned it off or it wouldn't start. that trick lasted about two days. I have since replaced the starter, the netural safetty switch and relay. i checked the ignition switch it was ok. after i replaced the switch and starter it worked until i moved it then it wouldn't start. I have discinected the battery to reset the computer and still it won't crank. any sugestions?
