HELP ASAP!!!
chitown_240sx
Car: 1993 Nissan 240sx SE Coupe
I have a cut wire on my engine harness... Can't i just get the wires I need and tape them together??? That should work right?
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
you should look at a wiring diagram in the FSM and make sure there the right wire. you could twist em a tape em if you want to be a hack. the right way is to solder and heat shrink em
chitown_240sx
Where is the FSM????
chitown_240sx
Nevermind don't answer that... My car didn't come with one.
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
You're asking for problems down the road if you simply twist the metal innards of those wires together and tape them.
I suggest soldering them together and either heat shrink wrapping or taping nicely.
If it's too hard of a location a butt or crimp connector will work for the time being. Just make sure you strip enough insulation off the wire for a good connection.
Wc240
97 Nissan 200SX
06 Scion xB
FSM is factory Service Manual. pretty sure your car has one search for it
