HELP asap on taking valve covers off to replace gasket
unknown007
Car: White 1993 Q45 (G50)
I know it's silicone but oil goes through.Trying to redo it/replace it.I searched and searched for how to and everything and help?I got the passenger side all clear just have the bracket that holds the plugs in that's near the manifold.Couldn't take it out will do tomorrow sine it took me 2hrs+ just doing that side.Also found out the radiator hose was put on wrong from previous owner.That's why it was leaking before. Brushed it all off and looks clean now.
Back to the valve covers if there's any link or thread here on how to do it would help a lot.Gotta get it done before Christmas or my car stays in shop until next year. While im at it im going to maybe bead blast them or clean them.
Also is it hard taking the manifold off?wanted to clean that too but i wanna hear if it is.
If there's and write ups that would help too im just stuck on how to take it off all hoses are off too by the way eve the fuel lines which threw fluid all on my hands.
Thanks.
-Berner
Q451990
To answer your second question first about pulling the plenum, even experienced techs. call it the "damn spider" for a reason!
http://www.q45.org/plenum.html
Here's a link to Jeff's write-up on changing his valve cover gaskets. Keep in mind that he's working on a '94, so he used a rubber gasket vs. RTV on the older Q.
zerothread?id=107690
Good luck!
Heath
unknown007
Thank you very much you are my hero haahah not but thanks.
Doesn't matter if it's rubber or not as long as it helps me take it off.
unknown007
Does say how to do the passenger but i think all i need to remove next is the bracket that hold those plugs.
Q451990
It has been about 8 years since my last DIY rocker cover reseal, but I don't recall removing that bracket.
Heath
unknown007
Oh well then it's the hose i have to yank out then. Even harder.
unknown007
Got the passenger off talk about a B***H!!!Now im on the driver took of the throttle body and should be simple after that im hoping.My gasket was ouyt like i saw oil leadking from the bottom that has been before.Oh yeah a solenoid broke too i gotta replace it cant forget that.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
What solinoid?
Passenger side is easy as cake to do the plugs, but I can't imaginge doing the valve covers on either side.
unknown007
na its harder than you think alot of plugs cracked like when i pushed to release them.
on the driver side right where all those hoses come in and you gotta remove those to take off the plastic.Its under there.
Infinitiguy19
Yea the plastic is very brittle, be thank full you don't have to do the hoses YET.
What plastic cover do you mean?
unknown007
ppastos wrote:Yea the plastic is very brittle, be thank full you don't have to do the hoses YET.
Id take pics but the cars in school.My teacher said my motor has been ran very hott before im guessing overheated.The damn previous owners dont know how to do anything. My radiator hose was but on wrong, Some screws were stripped,just stuff that stupid people who dunno about cars do when repairing. But its right where those 5/4 hoses connect its on the driver side right under the place cover.Theres a plug going down and i tried popping it off and it just broke.
Infinitiguy19
What does the plug go to?
That can all be repaired as long as the motor was'nt overheated, The only way to know is to do a leak test and a compression test But neither is as good a written proof of an overheat.
Good luck and happy repairing.
unknown007
well maybe not overheated but ran very hott.
