slickroger wrote:thanks guys ill try to do a check tomorrow.
You wouldn't happen to have a diagram of the lines I need to check do you?
Start by looking around the hoses in the following images. It's a gross leak so it should be pretty obvious where it is leaking. It's gonna be somewhat difficult to look at all of the hoses around the EVAP canister but you'll have to get your head up under the car to get a good look.
EDIT: For some reason I uploaded a picture of the 3.3L EVAP lines earlier. The above pictures are the EVAP lines for the 3.5L.
Modified by Pwnin O'Brien at 8:49 AM 3/20/2010
