Help, all the power windows stopped working.
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
edtrek
Car: 2009 Versa SL
One day they worked, 2 days later they stopped working, at least they were up. The fuses, breakers & links seem to check out. Any suggestions?
2009 SL HB
Shad0wXCalibur
Car: Nissan Versa SL Sedan
The main switch assembly may be defective. The other switches won't work without that one. Could also be something to do with the BCM. Not sure. If it's under warranty, a dealership will fix it.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
edtrek wrote:One day they worked, 2 days later they stopped working, at least they were up. The fuses, breakers & links seem to check out. Any suggestions?
2009 SL HB
Where did you check the fuses? What locations in the car?
edtrek
Car: 2009 Versa SL
2009 SL HB
Under the dash, under the hood toward the front (side to side w/black cover) the links on the positive batery clamp.
I checked everything electrical, they all work but the power windows.
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
I think you missed one spot. Check this out. It may be in your IPDM.
http://www.youtube.com/watch?v=tazwT1wqodw
edtrek
Car: 2009 Versa SL
It was the BCM, replaced under warranty. Two days later the windows stopped working again.
Return to “Versa Technical Discussions”
