HELP, all electronic compnents stopped working suddenly
Q45dude
Car: 94 Q45
I was sitting in the car during my lunch time with windows half way down. I was adjusting the seat when all of a sudden I noticed I bring the seat back no more, neither does the passenger one work, none of the windows work, sunroof doesn't function, however the dome light works.which fuse is causing this ? please help cause now I gotta drive with the back of the seat half way down
Assuming you already checked the fuses, how does your negative battery terminal and cable look?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I remember a main fuse going bad on someone elses Q and it did this.
Q45dude
Car: 94 Q45
I didn't have time to check all the fuses since I had to go back to work. The battery connections are good and new.
I'm assuming the main fuse would be underneath the HOOD?
elwesso
2007 BMW M Coupe
Q45dude wrote:I didn't have time to check all the fuses since I had to go back to work. The battery connections are good and new.
Yeah in the underhood fuse box
Q45dude
Car: 94 Q45
can't wait to get off work
Rex
Car: None
Here's what I found
zerothread?id=134381
Seems somewhat applicable, but limited information??
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
Definatly some kind of main fuse........
Tip: check under drivers/passenger seat, for any items that may interfere with power seat movement. Something could get stuck, resulting in a short.
Q45dude
Car: 94 Q45
Yep, it was the fuse.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Can you tell us which fuse ??
