maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Mon Jun 23, 2008 4:43 pm
Here is a post from the Yahoo board that is very comprehensive.
Yes, you do need a license to work with R22 and R134a. Yahoos don't have the machine to captures teh refrigerants so they go into the atmosphere and do no good and are persistent.
A/C systems work through a compression and decompression of gasses/liquids. Much like a can of compressed air gets cold when you release the pressure, liquids inside your A/C system, the portion inside your passenger compartment inside the dashboard gets cold when the compressor-created liquids go through a small valve and expand into a gas. The gas is returned to the compressor and re-compressed into a liquid.
When you run low on this liquid (a refrigerant), one of the symptoms is thatyour compressor will not work, to avoid damaging it. This is done with alow-side pressure switch. In other words, you MUST have X pounds of pressure seen before the compressor will kick on and allow your A/C to work. There is a high side pressure switch for safety purposes to ensure that the compressor doesn't run continuously and blow out the tubes. blockages of compressor parts inside (worn down or broken) can block the expansion orifice where the conversion of liquid to gas occurs (right at your firewall in the engine compartment) which give that cooling effect.
Leaks often come from old/worn seals, corrosion that comes from acidiccontamination (mixture of refrigerants and non-refrigerants, like sometimesair), old/worn compressors, or damaged compressors.
While you can buy a can of refrigerant (R134 in your case), and put it in toyour system via a special hose/connection, it may just escape as well, due to any of the above causes. Sometimes very slow leaks in seals take a long time to leak out, so that may work for you...for awhile.
Air conditioning systems have 2 external connections, a high and low side port. They are different sizes, for safety reasons. A high side port can show several hundred pounds of pressure, which would destroy any can you attach. This high side is seen AFTER the compressor. The other port (low side) is also called a "suction port", because it has a gasseous side that is fed or sucked into the compressor. This is the port that you fill your A/C side on.
You typically attach the hose from the can of refrigerant and then connect to the low side suction port. The refrigerant will flow into the system, andhopefully, the pressure will get high enough to trigger the low pressure safety switch to let the compressor run. But it wont' run as efficiently as it could, due to air in the line that is being compressed.
A proper A/C job would be to diagnose why you have leakage (and it may be a very slow leak, but then it could also be a worn seal or worse).
After fixing it, certain parts are replaced if your system was opened up, assome parts have very small passages that are extremely hard to clean out and it's easier to ensure that it's replaced than to worry you didn't get something out of it. There is also a "drier" in the system that absorbs water and pulls it away from the air conditioning refrigerant. When you get a hole in the system or open it up for service, the water in the air starts being drawn into the drier and uses up the dessicant there. So it's often replaced as well.
Then a pressure test is done with an inert gas to avoid leaving any residue that could mix with refrigerant or eat at the A/C system and lines later.
Then all gasses are vacuumed out with a 2 stage vacuum pump for a long time, to allow any liquid water stashed deep in your lines to boil away - just like you might see a soda releasing bubbles when you turn the cap. But this vacuum takesawhile, and also is used to see if you have any holes in your system.
Then, with a very deep vacuum pulled on your system, new refrigerant (andspecial oils if your system had parts replaced) are added. It will take somepart of the refrigerant on its own, due to the vacuum, but it will require thatthe low pressure switch get activated, and then the compressor kick on, and suck the remaining amount needed.
Filling it too much or too little can lead to poor performance or even failureor non-operation of your A/C system.
Too much to learn, I know. But trying to explain what's going on inside, andhow a can added to the system may help temporarily, but why it might be good to get a service call made. These repairs can be expensive...
My 99 Infiniti had a clutch seize up, destroying the seals on the compressor. I replaced the compressor, seals, drier, hvalve, vacuumed and refilled the system, and it's going great over a year later. I'm also a licensed A/C tech (well, it took 20 minutes online with an exam, but I understand the physics behind what's going on.) I'm also obligated to follow EPA rules regarding the storage of reclaimed refrigerants. My tools aren't cheap. That's why people turn to those little cans on the shelf at walmart to refill their systems. But the EPA is eying the ability for consumers to even buy refrigerants, due to damage to theenvironment. Rather than incur severe wrath of consumers no longer able to cheaply keep A/C going, they try to find safer refrigerants to use that also work well. That's why we all went from R12 refrigerants to R134. It's not as effective, but it's much safer for the environment.
I know, all this is more than you wanted, but shoudl give you a greaterappreciation and knowledge for how the A/C system works.
There will be a test on Monday. :-)
Justin
