sir_vq »
https://forums.nicoclub.com/sir-vq-u130534.html
Sat May 16, 2009 6:34 am
in my time working for nissan. the airbag or(srs unit) wouldnt throw a code, the airbag fires when senors are compressed, the srs unit receive the signal in a chain of command which starts with, 1)the sensor being crushed which sends the signal to the 2)airbag control modulewhich lastly fires the airbag this all happens with a split second. if your having problems i would look at the airbag control module check it with a meter maybe there is a split somewhere, if you have power seat maybe the harness is stuck in the track and making intermitent contact with something when your wife moves around, also look at the bcm(body control module) these wreack havoc on nissan techs especialy in altima and maxima where change tends to get stuck in them and cause shorts.........one things for sure man u dont wanna be messing around with airbag and saftey stuff. and if your dealer aint takig the prob seriously i would have a real problem with that........sorry bout punct. and grammer did this off my iphone
