duffman1278 »
https://forums.nicoclub.com/duffman1278-u61344.html
Mon Oct 05, 2009 10:01 pm
Check that you're getting signal to your injectors, hook up a node light to it.
Verify you're getting spark by grounding the spark plug on the coil pack to the block and have someone crank it.
If one of these is not occurring, follow the wiring. If the spark plug is not getting spark then check the wiring TO the coil pack, ignitor and to then to the ECU.
If the injector is not getting a signal, verify the wiring to and from the injector. If you must, strip the loom and look at each wire very carefully.
Wiring grimlins are ftl
