help after cam install
fast_s13
alright so i have a built s14 sr20det car was running great till had put BC valves,springs,retainers and 272 cams.... problem is that it will not run on the fourth cly.. i have spark to it.. i just cant seem to get it to hit.....all the timing marks are lined pup and the cas is set right.... im using stock cam gears with the vtc....anyone have any ideas
sr20det0821
Car: 240sx
check to see if all you rockers are on and none of them fell off especially around the cylinder thats not firing
