The idea here is to tap into the sub wire (disconnect sub and use it for the converter or direct connect to amp). Since this is post-amp, it is a speaker-level input.PoorManQ45 wrote:But isn't the signal from the Bose HU just like a standard preout from other HUs, it just has a different end connecter on it.
I would not suggest simply swapping the sub. I'd use the subs speaker-level output and connect that to an amp (one that supports this or by using a converter). This will work with Bose or non-Bose systems.Silvia2b wrote:Correct! Yeah, In Non-Bose system taking the speaker level signal to a factory sub usually works perfect, although it requires an RTA to determine the X-over point of the factory amp, if it has one.
I would prefer the pre amp signal when connecting to a Bose system since they add wierd EQ adjustments and other oddities not found in many aftermarket products signal chain.
This is done to allow the system to play louder as awhole. Bass frequencies require the most power out of the entire frequency band. Attenuating the bass would "free up" power for other parts of the band, usually mid bass and mid range because they require the second most power.audtatious wrote: It seems that every increment over 5 starts dropping the bass levels on the Bose system. I assume this was done to keep people from blowing the factory system by cranking it to 30.
Mid-bass is attenuated as well. They can't "free up" power since each amp channel is limited by their own RMS. You can't pull from one channel to another unless you have some form of automated switching which is unheard of and too cost prohibitive in factory systems.PoorManQ45 wrote:This is done to allow the system to play louder as awhole. Bass frequencies require the most power out of the entire frequency band. Attenuating the bass would "free up" power for other parts of the band, usually mid bass and mid range because they require the second most power.
