Help!!!!! about to install lower control arm
240ight
Car: 90 240
It is a 90 240 i bought a set of front lower control arms from pdm racing and I was about to install them when a friend who thinks he knows about cars told me I have to compress the spring to take the ball joint with the fork out. When i visited the pdm website they have a step by step guide to replace them and it said to unbolt the two bolts from the brake assembly to the strut but doesn't say to compress the spring. My guess is secured to the strut? but now i am kind of worried about unbolting the bolts. any tips would be very helpful.last thing i want is the spring flying through the door or worst. Thanks
Jiggyfry
well, you can officialy slap your buddy, lmao. The spring IS secured to the strut by means of the top plate. Dont worry about unbolting the 2 strut bolts the spring wont fly off unless you undo the top nut that sits in the middle of the top plate. Install LCA and do a little dance and report back with info on it.
i wonder how fast lightning would be if it didnt zig-zag?
808DRFTR
Car: 89 240sx KA24DE Swap
91 240sx SR20DET Swap
02 Sentra SER Spec V
01 QX4 4x4 Lifted
01 I30
11 M56 Sport
Really easy to do, look at your new LCA and thats what needs to be removed & installed.
240ight
Car: 90 240
Thanks guys!!! I ve taken them off and pretty much every bolt is off.... except the ball joint is still attached to the brake assembly. I got the nut off (which was a bit** it was rusted) and have the fork seperator. Is there a trick to it? thanks guys you already have help alot.
SeVa-S13
Car: '05 GTO 6spd
A BFH.(hint: the last word is hammer)
jza80king
Car: 1992 Nissan 240SX
1998 Toyota Supra Turbo
hey guys i have a 91 240sx and I'm having some problems with it. I'm pretty sure its the lower control arms on the left that the bushing is dead. my car makes clunking noises sometimes when i'm driving and the steering pulls when I brake. then my steering wheel will be off center and all of a sudden it will jerk or pull back to the center. I wanted to ask you guys if anyone has experienced similar problems such as mine. I am also looking into gettng the control arms at pdm probably just the regular one but i want to make sure that is what is wrong. Also, I changed my steering rack just the other day so that is new, and I also had an alignment. Any help is greatly appreciated..
-Edward
SeVa-S13
Car: '05 GTO 6spd
I've never had that happen in a 240 but I'd definitely take a look at both your tension and tie rods.
jza80king
tie rods are also new, forgot to say.
Jiggyfry
Just get under the car and get a pry bar and start checking your bushings for play. Start with your control arms, then check your tension rods. Just keep checking everything with a bushing. Should be able to find it without much trouble.
