help about Swap RB20det into m30
sharshabel
Car: infiniti m30 & cefiro a31
hello sorry about bad english !!
i need help help about Swap RB20det into m30 any idea about BRACKET ?
sharshabel
i do this but its not ok
Carl H
that looks a bit sketchy for sure...
i would have extended the subframe instead of cutting the engine brackets.
sharshabel
soo any help ?
sharshabel
for up
help please
Carl H
no one can tell you how to build your mount kit, you have to use some imagination and engineering to make it work correctly.
if you are not sure how to go about doing this then perhaps it would be a good idea to have a competent shop make the mount kit for you.
Miguelone
Car: R33 Skyline 4 door
Honestly the easiest way would be to source an R31 Skyline front crossmember, Your car shares the entire front end(minus hanging panels of course) with an R31. An Australian Spec crossmember shouldn't be too hard to find if you try places like Australian ebay, r31skylinecub.com etc. It will bolt straight in, Hold your RB exactly where it's supposed to be and use factory engine mounts.
