HELP......94 Q45
Rokketarm
Car: 1994 Infiniti Q45
A friend of mine was looking at my MAF harness, touched 2 of the connectors together on the harness, heard a pop and now my car will not start. Any suggestions as to what went wrong?? What do I need to do to fix this problem? Any help would be greatly appreciated...Thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
First, ties his hands behind his back.
Next, check your ECU. Dollars to donuts it's fried. Might check with Wes to see if the upgrade will fix it.
Rokketarm
How do I check the ECU to see if it's fried? How easy is it to put install a new or used one? Thanks
ECU is located behind the kick panel on the passenger side floor.
db_autotek
Car: 1994 Q45t black & 1993 Miata racer. Previous: 1994 Q45, 1992 Q45.
I would start with the ecu too. Like Jesda said, just go to the pasenger side and pull off the kick panel ( 2 clips and one 10mm nut ). There is a way to put the ECU into diagnostic mode and so forth. You have to have a service manual to go forward. Your car should have one from the factory (thanks Infiniti) in the trunk by the spare tire.
If not, go to http://www.phatg20.net/modules...id=62
Now look to page 169, (or page 51 within the Engine Control and Emissions section) and that will help you put the ECU into diagnostic mode.
You said you heard a "pop". I strongly suggest checking every single fuse in the car. It might just be a $2 fuse and your back on the road!!
Rokketarm
I did the diagnostic test with the ECU and nothing came up as a malfunction. I also checked all of the fuses and their all fine. Are there any other fuses on the motor somewhere that I'm not seeing?? Any suggestions are greatly appreciated....
Rokketarm
Quick question: is it possible to fry part of the ECU, and still have the rest function? I'm getting no power through the wiring harness to the MAF
goody90q45
Car: 1992 Infiniti Q45 (sold)
Rokketarm wrote:A friend of mine was looking at my MAF harness, touched 2 of the connectors together on the harness, heard a pop and now my car will not start. Any suggestions as to what went wrong??
Read through this two page post by Amybirds who had the exact problem as you. I think the end result is that the ECU is fried. Hope this helps.
zer...age=1
Rokketarm
Goody, thanks for the link and info! I replaced the ECU today, and she's running like a champ once again...Just for future reference, ANYTIME you work on your MAF, disconnect the battery beforehand and you'll save yourself the stress and B.S. I went through. Thanks everyone for all of your help!
goody90q45
Goody= +1
Glad I could help.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
goody94q45 wrote:Goody= +1
Glad I could help.
Hey, I had the first lucky guess!
Glad you got it back on the road. Cuff your freind the next time your hood is opened.
goody90q45
maxnix wrote:Hey, I had the first lucky guess!
Oops. You're right. I'll take credit for presenting the compelling evidence.
