This has been a mind f#@k. This situation came on very quickly, 5 days ago all was fine & dandy... today it sucks....
The truck started to act like it had a dead battery, very slow turning starter, I charged the battery & it started up... well ok.... but something sounded funny while cranking. Then the next day it was dead again.
So I pulled the alternator & it checked out fine, charged the battery again, it again acted like a dead battery, very slow cranking. Next I had the battery load tested, it's good.
Now it's intermittent when I hit the key, sometimes it cranks very slowly, sometimes nothing, lights all dim like a dead battery,. The battery is reading 12.7v standing & 13.8 running.
I wanted to check the relays, there is one large blue relay near the battery on the fender, that has 2 plug ins. A rectangular black box that has 2 green relays (Fuel Pump/Main) & 1 Blue relay (Check) + 2-15amp fuses (Head lamps) 1 grey relay (horn). Back near the fire wall are 2 more identical blue relays. Which are the starter relays??? How do I check them?
So if I have to pull the starter, any suggestions? It looks hard to get to.....
Thanx Steve
