Help!!! 93 Infiniti J30 runs horribly after warming up!
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
ill test this this afternoon and see what happens. im wondering if your ecu could be having issues. i will let you know what happens when i unplug my MAF.
swimshark
when i unplug mine it did the same thing
gnogoss
You need ECU when you pulled the sensors your ECU should hv threw a code
I went through sumething just like this on my nissan maxima se 1995
i replaced every sensor on the motor
maf, camshaft, iat control, tps, and much more car stilll would not rev past 2000 rpms
I even changed the converter it did the same thing
than a manufacture control code came up your stuffs faulty
you have all the classic signs of a failed ECU
Q451990
:welcome: to NICO gnogoss!
It's pretty rare to see a dead ECU, but on rare occasions it happens. Usually due to damage from another electrical problem or water damage from a leaky windshield or poorly repaired body damage. If you have a pull-a-part style yard nearby, that will be your cheapest option. There are two '93's in my local pull-a-part... if you want me to pull one and ship it I can do that at cost to help you out. They charge about $25 plus whatever it would cost to ship it. No guarantees or warranty that the part is good or that it'll fix your problem though...
Heath
