Could be bad injectors. They go bad a lot on KA motor. Could be MAF too. Find another 240 in good running condition, swap out the MAFs and see.biggie wrote:More info on how its is running would help.
There are a ton of things it could be.
Fuel filter, Fuel Regulator, bad injector(s), fuel pump, timing, distributor, MAF, etc, etc, etc
#1 injector is bad. It's a very common problem. Bad injector usually stops working when engine is hot.I972OPELGT wrote:I pulled the wire from the first cylinder and when i did the engine would not run rougher which is what I expected, so it leads me to think I may have a either a bad injector or possibly the wire is firing weak. I can say though, the whole car shakes and has a horrible vibration.
Biggie and 94_240sx hit the nail on the head! It is bad injectors! I had the same problem with my 240 vert not to long ago. The whole car was shaking and idling really rough. One of my injectors was damaged and needed to be replaced. If you don't know how to replace an injector I would find a local repair shop.biggie wrote:More info on how its is running would help.
