DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon May 05, 2003 5:22 am
The MAF is my first guess since it's attached to the top of the airbox. A bad connection would cause rough running, but not missing I don't think. The CEL might be related to the misfiring...check your knock sensors. I'll post a link to a procedure later.If you have to mash the pedal to the floor to get the car started, then it's flooded (pedal to the floor shuts off fuel at startup). Once the car is started, wiggle the MAF connector to see if there's any effect on the idle. You can either reset the check engine light manually, or disconnect the battery for 24 hours. The manual reset is more work, but the procedure will also reveal the error codes setting off the CEL to give more insight to the problem. How many miles have you put on the car since buying it?
