Ok first things first, good call on cranking it with the pump relay pulled. Never work on the fuel system without releasing the pressure
Now, your fuel injectors are going to be crappy either way because they are old style. Pre-1993 injectors are prone to failure because the ethanol in today's gas basically corrodes them from the inside. There is a conversion kit that will run you about $120, but you will have to pull the plenum (or dremel the remaining injectors) and solder in the new style electrical connectors.
As for buying remanufactured injectors, there's nothing wrong with buying new style remans but not old style. I have a new style set on my 90 NA with the adapter kit and I have zero problems.
Yes, its very likely that you pinched an o-ring on the install. I did it twice before they finally seated correctly. The easiest way to tell is with it running, do you smell fuel near the plenum? If so, its leaking. That will for sure make your exhaust smell like gas. The other possibility like I said is just bad injectors.
IMO, you should save up for a few months and get the adapter kit (~$120 from Z1 or whoever), a reman'd set of new style injectors (~140 on ebay from seller tlfperformance), and new fuel rail insulators (~$10 or so). It's really not a huge undertaking, but when you go to install the injectors, use PLENTY of lube. I know you said you used "a little" vaseline, but that's what I did the first time and 2 of the o-rings pinched. You gotta make sure they are lubed up good.
And yes, the injectors should all ohm out between 10-14 ohms. Great indicator of bad injectors if any are outside this range
