Rucca wrote:Why have you not questioned your ignition switch? Rockauto.com is selling them at closeout for 20bucks
Why replace a starter? Haven't you proven that it works flawlessly?
The reason I hadn't questioned the ignition switch is that I've heard a subtle clicking (NOT the starter solenoid) from the engine when moving from the RUN to the START position - I've been presuming that was the starter relay but perhaps it could have been another relay unrelated.
What's frustrating is that short of completely bypassing something - I can't 100% prove it's flawless in an intermittent situation. I can prove it's worked 100 times in a row on the bench. But who's to say that 101st time it might have done nothing? Everything else I've either bypassed or replaced and had the problem manifest itself. But yeah - I'd just as soon NOT replace this rather pricey and to me seemingly good starter motor.
But for $20 it's a no brainer to try your suggestion at this point.
I like the suggestion and appreciate the $20 recommendation - How hard is it to get to the ignition switch inside the column and replace???
