tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Tue Feb 10, 2009 5:21 pm
My friends 2003 350Z Touring 6MT is having some hesitation issues while driving. The only mod he has is a AFE short ram intake w/ heat shield.
During the first 20 mins of driving the car hesistates under HARD ACCELERATION.
When you hit about 3000 RPMs the engine feels like its getting no gas/spark because it feels like you are getting half the power you should be.
This problem happens sporadically. It has no gear preference. Sometimes 1st, 2nd, and 3rd gears pull hard, and then you go into 4th and BAM, instant lag like you hit a wall. Sometimes it happens in 1st, sometimes in 2nd....
If the ambient temperature is above 40-45* then the problems are nonexistant.
We just changed out the spark plugs, so that is not the problem. There have been no CEL codes. No issues with idle. Swapped TB, that's working just fine.
TIA.
