clovers525e »
https://forums.nicoclub.com/clovers525e-u47904.html
Mon Aug 03, 2009 4:35 am
Ok, before anyone says anything, yes I’ve bleed my brakes 20 thousand times.
Now, here is what’s going on. I swapped out my rear rotors (s14), pads (s14) and hubs for stock s14 stuff, swapped out the front spindles (s14), ball joints (s14), rotors (j30) and calipers (j30). Initially I left the rear calipers the way they were and didn’t touch them. I did how ever pop a piston out on accident when I tried to set one of the brakes and then noticed a small pin size hole in the caliper boot.
When I got everything back together the brake pressure was nothing so we started bleeding. We used around half a large bottle of brake fluid from advanced. After some time we noticed that the brake pedal would build pressure but as soon as it was left to rest in the up position, the pressure would drop quickly. We only bled the fronts initially because they where the only ones removed. After we talked about the hole for some time we considered the possibility that air was entering the system there. So we replaced both rear calipers with s14 ones, still nothing.
My question is, is the stock s13 master cylinder large enough to power the new and larger front calipers (j30)? Has anyone herded of a problem like this, where the system must have been properly bled but the system would not hold pressure? There are absolutely no visible leaks of any kind and care was taken to not allow any air into the master cylinder while bleeding.
Also on a side not, it seems like the system will build much more pressure while bleeding when the pedal is pressed from say half way down to the floor instead of letting it come all the way up to where it normally rests.
The way it feels today is easy to press down to the floor, a slight resistance but nothing big at all.
