Young explorer »
https://forums.nicoclub.com/young-explorer-u211994.html
Sun Nov 11, 2012 5:41 pm
I had the exact same problem with my 240sx,..I just finish doing a head gasket replace, test drove it and no problem for couple of days and then next time I started the car it turn over for a few minute and die out,..and after that it won't turned over,..it took me months to find out the problem,.I had to replace the ECU twice because it was burnt out,..finally I trace the problem and found a grounded wire located next to the injector between the head and the block,..I had to trace every single wire that is wrap!....it was a black wire that was smash flat exposing just one bear wire,it is hard to see the expose wire you need to really look closely to it,..with a very bright light,..that one single wire was slightly touching between the head and block that causes the ECU to fried...
