OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Wed Oct 21, 2009 2:40 am
No you have relays, you have harnesses, wire is cheap, especially on that engine.
Just rewire it, do it right, and be careful, fuses are good.[/QUOTE]
Your car is carbed so you have a starter power wire, and a signal to the starter solenoid, engine ground, oil sensor, electric choke?, and some gauge wiring?
For the started you can use all the Nissan stuff, guages well in the cluster there is 2 ignition power sources for gauges.
Save the 600 bucks
