I've been dealing with the dreaded rear air suspension leaks on my 2011 QX. I've replaced the compressor dryer, o-rings, etc, etc... still leaking. Next steps are too costly to "guess" at the solution. I want to address the problem and root cause... sagging rear springs. The air leveling system is garbage and only intended to compensate for heavy loads anyway, which i rarely have. Right now, when all the air leaks out of the system, the rear suspension sags so much the truck nearly rides on the bump stops! The tops of the tires tuck under the wheel wells.
Are any specs available for the factory rear springs? has anyone replaced them to get ride height restored? Do i need aftermarket springs, or are OEM springs enough?
I do NOT want a lift... I simply want to get ride height back to normal without having the air leveling system needed.
