So quite a while back.... I noticed a bumping noise on my way to work. The liftgate was not properly locked/shut and also would not operate at all. Not with the fob, not with the button on the liftgate, not with the dash button. (and no the liftgate cancel switch is not on/off) I stopped off at a Discount Auto to see if it was a fuse, etc. since it was on my way. Could not find any bad fuses. But coincidentally while under the hood the mechanic noticed my battery had serious corrosion on the terminals. Since no solution and I had to drive a good way to work, took it in to the dealership. After keeping it all day, they told me the entire motor was bad and a $900 fix. I said no thanks, wanted to get a second opinion or have my hubby DIY for cheaper. So the only way to lock or unlock is manually in through the back of the car with the panel off and flip the lever. Since this happened, totally forgot about the battery corrosion for a while, until battery problems. Long story short a couple of times the liftgate worked, but only for a short period, and only after un-hooking and re-hooking battery. Sooooooo..... I feel like it is not the whole motor?! How could it possibly work briefly if the motor was dead? Any expert ideas or thoughts out there? Or am I totally off.... Just really don't want to spend $900 for just my liftgate to work.... HELP !!!
