HELP. 2005 Nissan Rattling Noise
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
Peba23
Car: 2005 Nissan Altima 3.5 SE
I have 2005 Nissan Altima 3.5 SE
Couple of months ago it started to do very bad rattling noise in idle.
I heard allot of different stories on what can be wrong.
I have a video of the car running with that noise.
Wanted to see if anyone had the same issue, and how should I fix it.
Any ideas will be appreciated.
Thanks.
Peba23
Here is the video of the noise.
[youtube]http://www.youtube.com/watch?v=GqQQgPX- ... e=youtu.be[/youtube]
Reason: Fix video link
jdshift
Car: 2019 Nissan Altima
2015 Nissan Altima 3.5
2014 Infiniti QX70 S 5.0
Hello, my question is does the sound get more high pitched upon acceleration? I had a similar sound before but not as bad, would rattle like crazy and the Nissan Tech said it was caused by a under heat shield in which he removed and the sound was gone. Hope this helps or you find the issue if it differs.
Inkman1108
Car: 03 Altima 3.5se Sonoma sunset red, new motor, headers n full exhaust, NWP 5pc intake spacers,underdrive pulley, injen RD CAI, strut bar, KYB-GR2 struts n shocks, spoiler, front lip,
Peba23 wrote:I have 2005 Nissan Altima 3.5 SE
Thanks.
How many miles? If ur getting up there 100k or better. It's your timing chain slapping against cover do to tensioner becoming worn and there is a guid rail that sits on tip of hydrolic tensioner that can drop down. The tensioned are run off ur oil pressure. When u first start and at idle if your oil is low or old. It will slap n u hear it! It cost bout $1000 to have shop fix it. Calls for 11 hrs in book. Easier to pull motor n change timing chains ! Let me know
Tonyjimenez78
Car: 2003 Altima SE
2005 Altima SE
We're you able to replace the chain?
enavy58
Car: 98 Infi I-30 Jade/Tan AT Stock, 05 Niss Altima SE-R 3.5 Blk/Blk Stock
https://www.autocodes.com/uploads/nissan/NTB05-095.pdf
Nissan Technical Service Bulletin regarding rattle noise. Worth a look
Return to “3rd Generation Altima Sedan (2002-2006)”
