HELP! 2003 spec v
yellowspecv2003
Car: 2003 sentra ser spec v
i have a 2003 spec v and lately when the car is warm at normal temp everytime i take of i hear like this chain or something i was thinking the timing chain?? anyone have any idea what that noise is sounds like it comes from the right side of the front
nametakennow
Car: '06 MINI Cooper S
Right side as in passenger side? Pop the hood while it's making the noise and see if you can get a better idea of where it is.
It's common for the heat shield on the exhaust manifold to get a little loose. That's the most likely culprit.
I assume the engine is running fine through all this?
SillySpec
Car: 04 Spec-Vq30de-t
maybe its the motor mount?
I doubt it would be the timing chain
yellowspecv03
its only on the take off or on like 2 gear but low rpms
ProudNissanFreak
Car: 2005 Imaginary WRX STi, 2003 Civic
It's the heat shield, I'm 80% sure as this happened to me too.
