bobnsofi »
https://forums.nicoclub.com/bobnsofi-u187730.html
Wed Jul 20, 2011 10:05 pm
OK, for those who follow, the Camshaft sensor for Bank 2 is on the drivers side, it is the bent one (the passenger side is straight). Search an auto parts web site and you will see a strait and a bent one
To get to it, lean over from the passenger side. It is mounted on the back side of the engine on the drivers side in the camshaft area (so top) of the drivers side almost at the firewall. You can easily see teh passenger side one, so it is in the same place on the drivers side of the engine, hidden & covered by the intake
Reach in for it from passenger side between firewall & engine (it is hard to find!)
push down on the easy to get to side of the wire connection plug to free it. Go after the bolt with a 10mm socket.
It could be done in 10 minutes with these notes. It took us alot longer to learn where it was & how to get to it.
thanks for all your tips and the FSM helped also!
