HELP! 2001 Pathfinder Speedo and Fuel dash lights Out/Intermittent
am0rak
Car: 2001 Pathfinder SE 4x4
Hey guys,
I have a 2001 Pathfinder 4x4 with about 132,000KM (82k miles).
Recently, the dash lights for the speedo and the fuel gauge have not been turning on.
At the beginning, they would come back after driving a bit, but now it's gotten worse and worse, to the point where hy haven't come back in about 4 days!
It seems like a loose connection, but I just don't know where to look!
Can anyone give me some ideas on the cause and where to begin looking?
Thanks!
Modified by am0rak at 11:07 AM 12/11/2007
toolman911
Car: 2002 Pathfinder
I have the same issue with a 2002 PF, also remaining dash lights seem dim. Help!!
silver pathfinder se
Car: pathfinder 2001
I have the same problem. The dealer said it was the dimmer swith, I picked it up after they replaced it and it didnt fix the problem. I took it back and they are going to take the gauge cluster out to check connections. I spoke directly to the mechanic, he said it may have something to do with the temp. of the truck, once it warms up in the cabin the lights come on etc. I experience the same thing, no speedometer or fuel light until 15+/- minutes after the truck is on. Ive beat on the dash, tried all switch options (auto, on, etc) nothing made a difference. I would like to hear any input on this so I can tell the mechanic at the dealership, my appointment isnt until early next week (3/10/08).
Thank you in advance.
spandya01
Car: Nissan Pathfinder 2002
So I have a similar problem in my Pathfinder 2002. In my case it's the tach and temp, i.e rt. side of the gauges that are intermittent in nature. I don't see any correlation with outside, engine or cabin temperature. What did your mechanic do? I suspect it's a loose bulb.
Let me know if you can.
Thanks.
Samir
LugNutZ
Car: 04 SentraSER Spec V 01 Pathfinder SE
I would try looking at grounds and fuses. Start there.
92SR20S13
Car: sr20det-s13
LMAO...This happend to me ONCE so far....and i was like oh **** what the hell is going on..smacked the top of the dash and bingo it came back haha. But my headlights dont work
Tomzr2
Car: 2001 Pathfinder 4x4
Same problem with speedo and fuel gauge light. Tach and temp side work. Started coming off and on at first. Now went completly out. Seems like someone out there should have a fix.
Adnan
Car: 2001 Pathfinder LE 4WD
weird....i was just about to make this topic
yea my 01 pathy has the same issue for about 2 weeks nowand eversince its been happening frequentlysometimes they would all drop as if the ignition was offand the odometer would go all inky...and on some other occasion it would simply freeze to the speed i was driving at
nheitz
Car: 2001 Nissan Pathfinder LE AWD
My 2001 has also been doing this for 6 months or so.... right side (tach) on mine. It's been on for the last month or so though. It was off & on before that but couldn't find a correlation.
gund0166
I have the same problem and has been happening since winter of 2006. It seems to occur frequently in cold weather and when the car warms up it occasionally turns back on. Does anyone have a solution?
cmx378
Car: 2002 Nissan Pathfinder Chilkoot Edition (XE)
I know this is an old thread but I'm going to give it a shot...has anyone been able to resolve this issue? The right-half of my dash doesn't light up either. At first it was an intermittent issue and temperature does seem to affect when it happens more frequently, especially during winter. However, even after driving the vehicle for 30+ minutes and having the interior cabin temp. warm, the lights don't come back on anymore. Since no one has posted a solution, have all these people who posted the same issue just learned to live with no dash lights on the right-half of their PFs? The functionality of the temp. gauge and tachometer both work, there's just no lights! I know it's not the bulbs, so I'm thinking it's something to do with the circuitry of the dashboard, a wire, or a wiring harness? Can someone from this thread please post an update if you were able to figure out what the issue was? Please and thank you!
